Washer fluid sprayers not working?
Hey guys!
Old to the forums, but new to the S197! Just bought a 2014 3.7 Grabber Blue the other day after having my newedge for 5 years! So one thing I noticed was that the washer fluid sprayers do not work. The wipers do, as well as I can hear the sprayer motors working. Most likely it is a clog, but the sprayer tips do not looked clogged at all. Any tips on where to begin my search for my clog? The car is under warranty, but I dont want to take it to the dealer for silly washer fluid sprayers
Thanks!
Thanks!
Alright cool I'll check for that type of line. And oddly enough, the first time I tried it there was no washer fluid in the reservoir. So I filled it up, and still no dice. I'll have to have a root around the engine to see if I can find that line. Have yet to do any real digging. The dealer told me to check the sprayers, but from what I can tell they are not clogged at all. Thanks for the replies
1) Is there fluid in it? (Hey....I'm just saying...)
2) It may have run empty and the system needs to be primed a bit. I have noticed that some vehicles take much longer than others to do this
3) Clog would be my next item to investigate
4) Replace pump as final option. I'm guessing it is a pretty cheap part.
Hey guys!
Thanks!
Thanks!
Brand new cars shouldn't have this issue. If you didn't take it in then you should.
