water on computer"brain" passenger side05
Old 01-02-2015, 03:02 PM
bob77
bob77's Avatar
Default water on computer"brain" passenger side05
Hello people, new to your forum, I'm bob77 from Mass. Hoping to get some feedback on a water problem...Heavy, Rainy days, Water is getting onto the Main "Brain" on passenger side of my 05.behind the kick plate.Think its coming in from inback of wheelwell splashguard . Then running down along cable to inside car. Anyone every have a similar problem. Thanks for any insite to this. I'm presently trying to track down problem.
bob77 is offline
Old 01-02-2015, 03:32 PM
DRAGUL
DRAGUL's Avatar
Welcome to MF. Did you make sure the drains are clear inside the cowl? The rubber drain fittings get clogged and water backs up and flows into the car. Water leaks are a known problem on this year, and there is a TSB for it.
DRAGUL is offline
Old 01-02-2015, 04:50 PM
07 Stang
07 Stang's Avatar
Welcome to the forum bob77. Sorry you have the dreaded water leak. Do try to get it fixed before it reeks havoc on your electrical systems. If you do a search in the 2005-20014 Mustangs, you will come up with a number of threads on the subject, but like DRAGUL pointed out, most of the time it was caused by the drain plugs being blocked by debris or gunk. Good Luck to you!
07 Stang is offline
Old 01-02-2015, 06:33 PM
austinkli
austinkli's Avatar
Welcome bob77.
Does it by any chance look similar to this?
Or this?
If so that is the cowl that a few above suggested.
It is located here: (right in the center of the pic)
And it looks like this when you pull it out.
austinkli is offline
Old 01-03-2015, 12:39 PM
07 Stang
07 Stang's Avatar
Originally Posted by austinkli
Welcome bob77.
Water leaking - YouTube
Or this?
Water leak - YouTube
that is nasty looking!
07 Stang is offline
Old 01-03-2015, 02:01 PM
Nuke
Nuke's Avatar
There are 2 front passenger side leaks; the one from the cowl is associated with the TSB and affects the 05's thru some 07's. It causes corrosion of the Smart Junction Box (SJB) and eventually results in all sorts of electrical gremlins. The other leak is associated with clogged cowl drain plugs. Water backs up into and thru the cabin air filter and leaks into the cabin but doesn't affect any electronics.
Nuke is offline
Old 01-04-2015, 08:50 AM
austinkli
austinkli's Avatar
Lol, that's the one I pulled out of my car.
Old 01-11-2015, 04:18 PM
bob77
bob77's Avatar
Hey Guys.. Thanks for getting that info to me.. big help, I'm working a lot, takes me awhile to get back to you goys . I'll check those things.. thanks..have a ? about the picture from "07 Stang"..that second pic that you show, small "can" type device...what is it and why would it contribute to water on "car brain" and fuse box.
Thanks bobby
bob77 is offline
Old 01-11-2015, 05:53 PM
07 Stang
07 Stang's Avatar
Thanks bobby
austinkli posted that picture, but I believe it is the drain plug. If it is full of gunk it will cause a leak that goes down to the smart box. It needs to drain properly. If it gets into the smart box it causes all kinds of electrical gremlins.
07 Stang is offline
Old 01-12-2015, 04:11 PM
austinkli
austinkli's Avatar
Thanks bobby
That is the drain plug that you will find underneath the hood. If you'd like, I could probably make a very quick video on how to get to that for you.
Quick Reply: water on computer"brain" passenger side05
