Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2014 Mustangs > V6 S197 General Discussion
Sign in using an external account
Register Forgot Password?
Search
Welcome to Mustang Forums!
Welcome to Mustang Forums.
2006 V6 Coolant Leak
Old 02-19-2015, 07:03 AM   #1
Oriolesfan89
Vehicle: 2006 Ford Mustang V6
Default 2006 V6 Coolant Leak
Hello all,
A week or so ago, after noticing my heat was not working, I discovered that I was completely out of coolant. I refilled my coolant with Prestone 50/50 and it seemed all was well. Since then, my coolant keeps emptying out and I'm having to refill it again every several days. I've done a few visual inspections and haven't been able to locate the specific location of a leak. Sometime when I'm driving or for a few minutes after cutting the engine off, I'll notice steam coming out from under the hood. I'd really like to figure this out and repair/replace whatever the leaky part is on my own because I'm training for a new job right now and probably can't afford any significant repairs until at least the end of next month. Any sort of help would be much appreciated.
Oriolesfan89 is offline   Reply With Quote
Old 02-19-2015, 07:55 AM   #2
07 Stang
07 Stang's Avatar
Check your thermostat housing. Unfortunately the OEM is made of plastic and over time will break causing your coolant to leak. If you do a search on this forum you will find a link for a metal and better one.
__________________
Blue Mustang Registry #363
07 Stang is offline   Reply With Quote
Old 02-19-2015, 07:57 AM   #3
07 Stang
07 Stang's Avatar
Check out these threads.....may sound familiar to you;
http://mustangforums.com/forum/4-0l-...t-housing.html
__________________
Old 02-19-2015, 11:43 AM   #4
Nuke
Nuke's Avatar
Vehicle: 2007 GT
Send a message via AIM to Nuke Send a message via Yahoo to Nuke Send a message via Skype™ to Nuke
The '05 thru '10 4.0L Mustangs do use a plastic t-stat housing. Cracking of these housings has been a chronic issue with many owners. Why some fail and others don't is your guess. My wife has an '06 4.0 and has had no problems but only has a bit less than 60k miles. I bought one of the aluminum housings for her car, just in case.
__________________
Rick
07 GT Prem: Alloy, MT, 3.55's, Steeda CAI w/Brenspeed tunes, FRPP Stingers, 275/40/18 Goodyear Eagle F1 A/S on SVT Cobras (OE GT500's), 14" shorty, Wheelskin side scoops & qtr window louvers, A-H rear window louvers, SHR honeycomb blackout panel, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
06 V6: Legend Lime, Pony Package, 14" shorty, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
Nuke is offline   Reply With Quote
Old 02-19-2015, 01:52 PM   #5
Oriolesfan89
Thank you for the help! I ordered an aluminum thermostat housing and will probably be back on here when it arrives for help installing it.
Old 03-01-2015, 03:29 PM   #6
Oriolesfan89
Alright, so I got the replacement upper and lower thermostat housing. I started trying to install it, but I'm having trouble removing the hoses from the thermostat housing. Any sort of help or tips would be appreciated. Thank you!
Old 03-06-2015, 09:43 AM   #7
07 Stang
07 Stang's Avatar
Oriolesfan89 did you resolve your issue? You can send Nuke a pm I'm sure he can help you.
__________________
Old 04-10-2015, 06:09 PM   #8
teetertotter
teetertotter's Avatar
Vehicle: Family, NRA .22 Rifle Shooting, Vol. VA Homeless Shelter, Vol. Elem. School, Boys&Girls Club Vol.
My thermostat failed on the way to my volunteer job last fall. The temp gauge was okay and only a couple minutes from job parking lot. Lucky. After almost nine years, and 130,000 miles, it failed. At the same time, all the hoses were replaced too. My mechanic replaced everything same day and good to go again. I think after 4 years and time for antifreeze replacement, I'll have him change out the thermostat.
__________________
April 06/ New 06, 4.0L, Auto, BLK, Pony PKG
S&B CAI, Silverstars, Ziebart Rust Proof, Tier 1
Mobil 1, 133K miles & drive year round.
teetertotter is offline   Reply With Quote
MustangForums
Ford Mustang
Paid Advertisement
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Emails Backup
