2007 Won't stay running -- Possible electric problem
My 2007 Ford Mustang 4.0L will not stay running. The car turns off whenever the engine fan turns on, or you turn on the AC, the headlights, the parking lights, or the right turn signal. Left turn signal bogs the car down, but doesn't shut it off. Dashlights, heater fan, brake lights, interior lights, radio, etc., all work fine. The connector under the Engine Fan Relay in the BEC is burnt, but the relay seems OK and the fan turns. I'm not sure where to go from here. Has anyone experienced a similar problem?
take a look at the smart junction box in the passenger side kick panel. check all the connectors. I'm willing to bet its getting wet when it rains or carwash, and over time its corroded big time. pull the sill plate off, then the kick panel. 10mm bolt holds it to the body. pull it off and inspect it. good luck
Thanks so much for the replies! I checked the SJB, all the fuses, and began tracing the wiring out of the BEC. Turns out that the problem was the ground connection for the headlight wiring harness. Cleaned that up and tightened it down and everything is working again. I ran across a post from another member who was having similar problems that put me onto the solution.
https://mustangforums.com/forum/4-0l...ing-issue.html
Thanks again!!!
Thanks again!!!
KEM Motorworks
08-14-2015 10:13 PM
