Console trunk release button question
Old 10-17-2015, 03:22 PM
folivier
folivier's Avatar
Default Console trunk release button question
On my 2014 v6 premium convertible the trunk release button on the console will still work when the key is not in the ignition. Anybody know if there is a work around?
It does disable the switch when I lock the doors, but would really rather it be disabled unless the ignition is on.
folivier is offline
Old 10-23-2015, 02:02 PM
SCCAGT
SCCAGT's Avatar
After a whole bunch of people complained about not having an inside trunk release button, Ford added one. We wanted something to open it without having to dig for keys, or find the blue button on the fob. Many cars have some sort of secondary way of opening trunk/hatch this way. some have cables, some have push buttons. Disabling it would defeat its purpose for the majority.
I'm sure it can be rewired to work only if ignition is on as you would like it to, but that defeats the reason it was installed in the first place.
SCCAGT is offline
Old 10-23-2015, 02:38 PM
movielover40
movielover40's Avatar
I think your in the minority there. Love mine not needing a key to pop it.
Might be different with convertible.
movielover40 is offline
Old 11-05-2015, 10:46 PM
Whiskers1340
Whiskers1340's Avatar
Default Trunk Release Button and locking up the Stang.
I have a 2014 V-6 Mustang Convertible and was leery of leaving it in parking lots with the top down because anyone could lean in and pop the trunk with my possessions in it. I didn't bother locking the car figuring that if the top was down they could get in anyway. Then I read in the manual that when the top was down and you locked it with either the door lock or key fob, it deactivated the console trunk release. However if leaving the top up but the windows down, to keep it cooler, you cannot deactivate the trunk button so someone could lean in and pop it open.
I also worry about using the fob to lock up because so many people say that others can scan it when you do and get in to your car when you've left it. So I use the door switch to lock up. I guess unlocking it in a parking lot with the fob is ok unless someone scanned it and followed you to your next stop.
Whiskers1340 is offline
Old 12-03-2015, 04:37 PM
macman45
macman45's Avatar
Good points. You can always unwire it and just use the fob like the early s197 guys
macman45 is offline
Old 01-14-2016, 10:23 AM
66and06stangs
66and06stangs's Avatar
I've always wondered why my 06 does not have a trunk switch. Then, I saw one somewhere and bought it. It took about half an hour to install, and I love it.
66and06stangs is offline
Old 01-14-2016, 10:51 AM
Goldenpony
Goldenpony's Avatar
Same here
Goldenpony is offline
Old 01-14-2016, 12:53 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Wire the positive lead from the switch to an accessory circuit that is only powered on when the key is set to ACC...like the radio 'on' circuit or one of the cigarette lighter circuits (better option).
Derf00 is offline
Old 01-23-2016, 09:39 AM
BrianK
BrianK's Avatar
I like the PB I installed in my 07 Vert - but I installed it in the glove box that I can lock if I leave the top down. I agree that having it 'live' begs for someone to push it and get into the trunk.
You could install a separate relay which is powered by the ACC circuit. The PB now works by 'shorting' the powered line to ground and you can't (probably) change where this is fed from. An interposing relay would work for you. Find a ACC power source and get a small 12v relay. When ACC is on, the relay would be energized. Then wire the Normally Open (NO) contact in series with the wires going to the PB.
BrianK is offline
jerrytubes
10-23-2015 12:11 PM
folivier
10-02-2015 05:34 AM
movielover40
09-15-2015 10:37 AM
scorp 1
10-01-2013 04:08 AM
Vegasrph98
07-09-2013 12:28 AM
Quick Reply: Console trunk release button question
