misfire + nitrous ?
Old 02-09-2006, 11:48 PM
chrisc
chrisc's Avatar
Default misfire + nitrous ?
so as some of you may have seen, i was driving decently fast one day and my dash started flashing the CEL, and people have generally agreed that this was because at those speeds my car started to misfire
i know that misfires and nitrous can cause some major problems so i was wondering what i could do before i set up my nitrous to control this misfire problem
thanks
chrisc is offline
Old 02-10-2006, 12:03 AM
scrming
scrming's Avatar
Default RE: misfire + nitrous ?
ORIGINAL: chrisc
thanks
Why is your car misfiring? I haven't checked into a flashing CEL... on the Porsche a FLASHING CEL was very very bad... Have you pulled the codes? (if there are any..)
scrming is offline
Old 02-10-2006, 12:10 AM
chrisc
chrisc's Avatar
i have not pulled codes because i dont have a tuner, the CEL was only flashing for only about 2 seconds and only when i was going at about 100-110mph
the only upgrade i have done to my car has been an AFE intake, do you think that the high speeds combined with out the tuned AFE intake could have done this?
chrisc is offline
Old 02-10-2006, 07:25 AM
scrming
scrming's Avatar
ORIGINAL: chrisc
I'm guessing it's teh AFE at WOT... not so much to so with speed... has more to do with RPMs and Throttle position... any sign of detontation?
scrming is offline
Old 02-10-2006, 01:41 PM
chrisc
chrisc's Avatar
ORIGINAL: scrming
ORIGINAL: chrisc
what would be some signs?
chrisc is offline
Old 02-10-2006, 01:44 PM
rygenstormlocke
rygenstormlocke's Avatar
ORIGINAL: chrisc
thanks
I never had the AFE trip the cel, where you using the nitrous? And if so, what shot were you running? Do you leave it on all the time?
rygenstormlocke is offline
Old 02-10-2006, 01:52 PM
rygenstormlocke
ORIGINAL: chrisc
ORIGINAL: scrming
ORIGINAL: chrisc
You will hear knocking under the hood, like something hitting metal...like a metal knock. Did you hear anything like that?
Old 02-10-2006, 09:55 PM
slejda
slejda's Avatar
My Guess Is That You Started To Float The Valves! Did You Catch The RPM When The CEL Started Flashing.
slejda is offline
Old 02-10-2006, 10:16 PM
05AV6
05AV6's Avatar
Rev limiter......
05AV6 is offline
Urambo Tauro
06-10-2016 03:28 AM
Omgitsa88Stang
10-05-2015 07:33 AM
bconboy
09-21-2015 12:52 PM
Sandmanbjj
08-21-2015 12:38 PM
Quick Reply: misfire + nitrous ?
