Wheel Bearing Removal - 1999 GT - MustangForums.com
Go Back   MustangForums.com > Ford Mustang Tech > Wheels & Tires brought to you by Tire Rack
Search
Wheels & Tires brought to you by Tire Rack Discuss rims and tires here.
Sponsored by Tire Rack
Click Here
Old 04-04-2008, 09:04 PM   #1
lcdr03
Default Wheel Bearing Removal - 1999 GT
Need help on how to remove front wheel bearing retaining nut. Current retainer but has a cage that surrounds nut. Contacted Autozone but there information indicates to remove cotterpin and castella retainer. The 1999 GT does not have a cotterpin arrangement. Any suggests would be appreciated. Thanks!
lcdr03 is offline   Reply With Quote
Old 04-05-2008, 12:39 AM   #2
Ridinsidewayz
Default RE: Wheel Bearing Removal - 1999 GT
You should be able to slide the retainer off the nut. If there is no cotter pin there may be some type of retainer to keep the nut from backing off. I would suggest picking up a repair manual.
__________________
I wanna go fast!!!!!
Ridinsidewayz is offline   Reply With Quote
Old 04-07-2008, 06:43 PM   #3
lcdr03
This year Mustang GT does not use a castle nut and cotter pin. Haynes and other automotive books do not provide information for the type of setup. What actually is designed is a multiple nut configuration with what appears to be a C channel wrapped around the outage edge of the Nut(s). The channel actual holds the nuts together as one unit. To remove the arrangement you need a 36mm socket and a lot of muscle. Once you pull the nut, the whole bearing/hub assembles pulls off...it is one non serviceable unit. Cost about $55-$80 depending on the brand. When you put the unit back on, Ford says to torque it to 258 ft-lbs.
Similar Threads
Wheel Question! (New member, hi folks) Tivo304 New Member Area 4 12-05-2015 08:46 PM
11" wide rear wheels/tires mmarsh3014 Wheels & Tires brought to you by Tire Rack 1 10-20-2015 09:08 AM
HELP! P340 p344 and is not the alternator! Golfsito GT S197 General Discussion 9 10-06-2015 11:02 AM
1994 GT smog pipe removal wawagner82 5.0L (1979-1995) Mustang 2 09-13-2015 09:02 AM
Steeda's S550 Mustang GT Axle-Back Exhaust System - Video Inside tj@steeda Steeda Autosports 0 09-10-2015 08:39 PM
99, bearing, front, mustang, removal, wheel
