Recommended tire size of 18x9 and 18x10
Old 01-05-2009, 05:29 PM
Fink
Fink's Avatar
Default Recommended tire size of 18x9 and 18x10
I just ordered some rims, 18x9 for the front and 18x10 for the rear, what size of tire would you recommend? I was looking at 245/40/18 for the front and 275/35/18 for the rear. Im also considering a 1 inch spacer for the rear as well.
Fink is offline
Old 01-05-2009, 07:08 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Is your car now, or do you plan to lower it? If so, I would recommend a 255~265/35 up front & 275~283/30 out back.
If you plan on running spacers you MUST replace the lug-bolts to accomodate the additional thickness of spacer, but think 1" is too much anyway. You will likely get rubbing on fender and puts additional strain on bearings and such. In addition, I would NOT use a spacer that has 5 holes AND its own second set of bolts. I think this is a bad way to go and consider it unsafe, but just my opinion. I run 1/2" spacers and have replaced the bolts with longer/stronger ones and feel 100% secure.
HTH
Jazzer
Jazzer The Cat is offline
Old 01-05-2009, 07:45 PM
Fink
Fink's Avatar
I was gonna put the tires on and see how staggered it looks and if I want a little more Ill look for some spacers. I dont remember if the spacers on AM were 1" or not.. I could be wrong.
Fink is offline
Old 01-06-2009, 08:00 AM
Jazzer The Cat
Retired Moderator
You will have a nice stagger and the wheel wells will be filled up FULL. Depending on the off-set of your wheels, you MAY have room to push the rears outward up to 1/2", as I did with these:
As mentioned, I had to replace my studs as the extra 1/2" needed to then mount the wheel is just not enough. The new wheels will be quite a bit further outward than current, so you will be much happier with the appearance.
Below are the ones I mentioned as a big NO NO:
Install the wheels/tires and see what you think. You will be VERY pleased with result.
Jazzer
Old 01-06-2009, 11:47 AM
OEWheelsShawn
Disabled at Vendors request
OEWheelsShawn's Avatar
We usually set up the 275/35/18 on the 10" and the 245/40/18 on the 9". Let me know if you want a price?
OEWheelsShawn is offline
Old 01-07-2009, 08:01 AM
Fink
Fink's Avatar
no price needed.. already got the tires picked out on tire rack.
Fink is offline
Old 01-07-2009, 08:46 AM
Jazzer The Cat
Retired Moderator
Dude...... your killin' Shawn hee
Old 01-07-2009, 08:59 AM
Fink
Fink's Avatar
I already bought the rims from OE... Black Saleens. I can't wait till Spring
Fink is offline
Old 01-07-2009, 09:06 AM
OEWheelsShawn
Nice! Tire Rack has good prices. We can usually keep up with them but they do have great pices. What tires did you end up going with?
Old 01-07-2009, 09:53 AM
Fink
Fink's Avatar
well I have no moneys right now(rims took it all away) but I was looking at either Kumho Ecsta MX or Sumitomo HTR Z II.
Fink is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
10-05-2015 06:07 PM
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
AMAlexLazarus
AmericanMuscle.com
09-02-2015 08:59 AM
Quick Reply: Recommended tire size of 18x9 and 18x10
