Go Back   MustangForums.com > Ford Mustang Tech > Wheels & Tires brought to you by Tire Rack
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-24-2009, 12:38 AM   #1
Stonefire
Vehicle: 2005 Mustang GT
Question Does bolt pattern or offset matter?
The rims I want are:
Bolt Pattern: 5x114.3
Offset: 35
The tires I want are:
255/35-20
They say they best fit 20 x 8.5 Inch 2005+ Wheels
Although the site looks like it sells rims for trucks should I be alright as long as the size matches or does the bolt pattern and offset have anything to do with anything?
And second I want to add 2.5" caps to these rims and I've read it's just pop off and on (after removing the entire wheel/tire from the car which isn't a problem for me as I'll do it prior to adding). Is there anyway to tell what size cap the rims use?
Stonefire is offline   Reply With Quote
Old 06-24-2009, 12:45 AM   #2
BA Mustang
ROTM Moderator
1967 Ford Mustang
BA Mustang's Avatar
Vehicle: 1967 Mustang Coupe
Send a message via AIM to BA Mustang Send a message via Yahoo to BA Mustang
as long as the bolt pattern and backspacing are good, you should be ok.
__________________
ROTM November!
Own a red mustang join this group: Red
Own an I6 mustang join this group: I6
BA Mustang is online now   Reply With Quote
Old 06-24-2009, 01:49 AM   #3
Stonefire
Please define "good" as in what should I be looking for?
Old 06-24-2009, 08:35 AM   #4
Jazzer The Cat
Wheels/Tires Section Moderator
2002 Ford Mustang
Jazzer The Cat's Avatar
Vehicle: '02 s281 #0014
The off-set/back-spacing on those wheels will be just fine for an '05+ ride.
As for centercaps, this can be a little tricky. The hole in the wheel will dictate the diameter of the cap as well as fitment. That is to say, the cap the wheel comes with is going to NEED to be reinstalled, in nearly all cases. You will very likely be able to purchase other caps and peel the face off and glue them onto the caps of your new wheels. I did this with mine and are just fine.
Jazzer
Jazzer The Cat is offline   Reply With Quote
Old 06-24-2009, 10:47 AM   #5
Stonefire
Awesome thanks you both
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
