Go Back   MustangForums.com > Ford Mustang Tech > Wheels & Tires brought to you by Tire Rack
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-13-2009, 10:08 PM   #1
TommyV8
2002 Chevrolet Camaro
TommyV8's Avatar
Vehicle: 2002 Chevrolet Camaro Z28
Default Front drag wheels: OK to use spacers and stock studs?
They're 15 x 3.5 Weld Draglites with a 1.75" backspace. I'm using a 5/16" spacer to get it to clear the caliper. With this setup I can get the shank lugs to turn almost 6 times (maybe 5 3/4) on the stock studs before they're tight. Is that enough engagement, or should I consider grinding the caliper down and/or running longer studs (which would require using open-ended lugs with my factory 16 x 8 wheels)? They're only for drag use, I'm swapping them on and off at the track.
__________________
2002 Camaro Z28 Mulletmobile
Automatic, 3.42 gears, stock converter
Airbox lid, full exhaust, drag radials
12.76 @ 109.76, 1.92 60 ft
TommyV8 is offline   Reply With Quote
Old 09-14-2009, 01:54 AM   #2
JD1969
Pro. B.S. caller outer
JD1969's Avatar
Vehicle: 4000 - 0 -.5 Yes, thats right. I tied half a race.
Send a message via AIM to JD1969
Tommy, that is the exact same thing I did on my SS. I ran it like that for a couple seasons and drove it on the street a little bit. It was fine.
__________________
GET IN THE RING!
RIP tripsevn7
4/1/77 - 7/27/08
Quote:
Originally Posted by Sidewayz6.0 View Post
I'd **** OPRAH!!!!!!!!
JD1969 is offline   Reply With Quote
Old 09-14-2009, 05:37 PM   #3
Sidewayz6.0
Super Moderator
Sidewayz6.0's Avatar
Vehicle: '88 GT
It won't pass NHRA nazi tech like that. But it'll be fine.
__________________
RIP Tripsevn7
Sidewayz6.0 is offline   Reply With Quote
drag, front, mustang, s197, spacers, weld, wheel, wheels
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
