I have not driven on any of the specific tires above, but can give you what I would recommend as the likely better dry traction tire between them..... IMO:
1. Nitto Invo's
2. Nitto NT555's
3. Falken 452's
4. BFG g-Force KDW's?
Your desire for 20" wheels will limit your off-the-line traction a bit, as it relates to good launching. The profile hights are going to ride your car a bit rougher than you are likely used to, so something you must learn to accept.
I like the Invo's for a couple reasons and would be the tread pattern and the softer compound than that of the NT555. I do wish it were a bit more solid on the outter edge, but is going to benefit the corners well, I believe. These are a pretty soft tire, so you will likely get a bit less mileage from them over the other 3, so overall cost of running them will be higher in the long run. Personally, I think that the softer tire will be more beneficial to the driving experience, so given the above choices, what I would do.
Jazzer
