summer max perf. tires/temperatures
Old 11-16-2010, 02:42 AM
danzcool
danzcool's Avatar
Default summer max perf. tires/temperatures
I looked around and couldn't really find what I was looking for. At what temperature range do summer max performance tires lose their effectiveness?
I'm talking on dry surfaces and non R compound.
danzcool is offline
Old 11-16-2010, 06:28 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Unless you are going to extremes on temp, I would pay no attention. Temps will typically rise enough to make somwhere around 8 PSI from cold to after driving a few hours. I generally start with 10 PSI below the max rating when cold and go from there.
Looking at your mods, I am curious what tires you are running?
Jazzer
Jazzer The Cat is offline
Old 11-16-2010, 12:22 PM
danzcool
danzcool's Avatar
I've got yokahama advan sports in the back, 285/45 (it may have only been 40 aspect) on 18x10 wheels.
Goodyear Eagle F1 Asymmetric in the front.
I seem to have good enough steering response, haven't had any issues with understeer.
Not exactly convinced the rears are all that great though. I expect some lost traction at lower speeds, but the other day, I laid some serious rubber at between 70-80. I was wondering if it was cool weather... but I think I may have the tire pressure a bit high (35psi), and lowering it should help?
danzcool is offline
Old 11-16-2010, 01:12 PM
Jazzer The Cat
Retired Moderator
I run my R888's at about 36 PSI at cold temps. They get up to about 40~41 on DD duties and are happy with them. They will not hold as well on really cold roads or until they get warmed up. Unless you are having this problem consistantly, I would not mess with pressure that has been good until this point.
Jazzer
Old 11-17-2010, 05:57 PM
Stoenr
Stoenr's Avatar
Colder temps = more power, and less traction with summer tires. Makes for some fun actually, lol. Give it the feel of being on wet roads in my opinion.
Stoenr is offline
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
mungodrums
09-28-2015 05:45 AM
M3hunter
09-05-2015 03:42 PM
Quick Reply: summer max perf. tires/temperatures
