AM Bullitt rim-need Pony/Tri-Bar center cap
Just put on my AM Bullitt chrome deep dish wheels and want to use some pony center caps. My stock ones on my 18" fan blades will not work. Has anyone found some that will work? Will the ones from the '04 and earlier cars work? They look like they are the right size. Any help is much appreciated. Thanks
If the diameter is correct, sounds like the plastic insert piece does not fit properly and is normally the case. I had this issue on my own wheels when I swapped my OEM Saleen wheels to the aftermarket ones I had widened.
Use a razorblade and peel ALL the stickers off of each plastic insert. Use silicone adheasive to glue the stickers/emblems you want onto the plastic inserts that fit the wheels you want. Allow them time to dry and your all good
Jazzer
Jazzer
The diameter is not correct. The caps on the new wheels fit in the hole where our caps actually sit on top of the hole. I have been told that the older '04 and earlier caps will work. They don't have the chrome ring around them and fit in the hole flush. I will be ordering some today hopefully. Thanks
OK.... so the cap fits like a bottle-top and overlaps the edges of the opening a bit?
If you have additional trouble, give me a pic and happy to help figure something out for you
Jazzer the friendly kitty
Thanks so much, appreciate the offer of help. I will post once I receive them. I did order them from a Ford dealer on Ebay so we will see. My local dealer wanted $35 a piece plus tax. I got them for $97 total shipped. Still kind of expensive but that is the look I want so you gotta pay sometimes. Thanks again!!
For those of you that have AM Bullitt wheels (maybe other AM wheels, I don't know) the '04 and earlier factory center caps will work perfectly. Got my center caps on today. They fit perfectly flush with the wheel and look just like they were supposed to from the factory. I am really happy with them. Anyone with these same wheels (AM Bullitt deep dish chrome) you can just buy the factory center caps for the '04 and earlier Mustangs and you will be good. Yeah!!! Here is a couple of pics.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
