315's 17x10.5" 98-04 Offset on S197
Old 04-20-2011, 10:18 AM
2005Redfire6
2005Redfire6's Avatar
Default 315's 17x10.5" 98-04 Offset on S197
Hey guys like the title says... I like how the 98-04 offset looks on an S197. Thinking about getting 17x10.5 wheels in the back with 315's. Anybody have any pictures of this setup on an S197? Do you think I would have any clearance issues?
2005Redfire6 is offline
Old 04-21-2011, 06:11 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
They are gonna be close to rubbing for sure, but will probably work.
I have seen lots of 10" wheels for those years on the S197 and they fit fine. The fenders are factory rolled, so is a big plus here. I recommend you hit up the S197 forums and see if anyone has reported clearance issues or anything, because that is pushing it for sure.
Jazzer
Jazzer The Cat is offline
Old 04-21-2011, 09:11 AM
AdderMk2
Banned
AdderMk2's Avatar
S197's run a much higher offset than SN-95 cars. You should fully expect the wheels to stick out like a mexican owned civic.
AdderMk2 is offline
Old 04-21-2011, 12:25 PM
Jazzer The Cat
Retired Moderator
A 10" wheel will be right at, or just beyond the fender edge. It won't quite look like that... lol
Old 04-21-2011, 09:31 PM
2005Redfire6
Hahaha ok guys thanks. I may just go with 285, but man those 315s are tempting and cheap at that!
Old 04-22-2011, 08:12 AM
Jazzer The Cat
Retired Moderator
I know Griggs needs to relocate the rear CO's a little bit inward when they install them on their cars. The CO's are a bit farther outward than the OEM located springs, so a 315 should fit on your car, but I just don't know enough about fitment to tell you exactly.
Take a look at Choosing a new tire and the section on "I want fat meats". There is a link to a guy that runs 12"s with little modification, so have no doubt that a 315 can be made to fit, just need to know the proper off-set to avoid rubbing.
Jazzer
Old 04-24-2011, 11:48 AM
2005Redfire6
Jazzer
Appreciate it Jazzer, I am going to do some more research to see if someone has done it before I get them!
Tivo304
08-28-2023 12:19 PM
mmarsh3014
Wheels & Tires
10-20-2015 09:08 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
gagemcc
09-22-2015 09:43 AM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
Quick Reply: 315's 17x10.5" 98-04 Offset on S197
