rear tire size on 17x9" Bullits
Old 04-29-2011, 12:56 AM
madmike90
madmike90's Avatar
Default rear tire size on 17x9" Bullits
Hey guys, i have 17x9" Bullits all around.
Im curious what a good tire size for the rear would be?
I use the car for street/strip duty. I dont drive in the rain and i dont really care too much about cornering, i just want good straight line grip
madmike90 is offline
Old 04-29-2011, 06:27 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
*little kitty tears fall like rain*
If you drive at ALL on the street, you are best to pick up a set of 15" rear wheels for 1/4 mile use ONLY.
A great tire for such a use is horrible on the street and should not be driven on one. A smaller wheel will allow you to run a higher profile for improved grip at the Christmas tree.
Is this a doable option?
Jazzer
Jazzer The Cat is offline
Old 04-29-2011, 09:47 AM
madmike90
madmike90's Avatar
Jazzer
certainly a do-able option.
but i am looking for a good tire for the street as well that i wont fry off if i try to step on it.
i have an intercooled P1SC
Old 04-29-2011, 10:02 PM
Jazzer The Cat
Retired Moderator
The only tire I see advertised as an "in between" one, is the Nitto 555R (not the RII's) Either way, an "R" comp is gonna be your best choice, because grip is what you need. Will just have to be a bit more fine with the throttle to avoid spinning is all.
Jazzer
Old 05-01-2011, 08:54 AM
Gray Horse
Gray Horse's Avatar
I have 275s on mine with Cobra wheels but would like to go a little bigger if I can.
Gray Horse is offline
Old 05-01-2011, 09:44 AM
Jazzer The Cat
Retired Moderator
^ please do yourself a favor and DON'T
A 275 is not only a max width for a 9" wheel, but is beyond what I think should be on one. They tend to bulge too much and create sloppy turn-in response and poor cornering due to roll-over of sidewalls. A 265 is not only a better fit, but will almost never rub where a 275 will almost always do so
Jazzer
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
Gary Ugarek
09-16-2015 08:04 AM
Mr. D
Wheels & Tires
15
08-22-2015 02:58 PM
Quick Reply: rear tire size on 17x9" Bullits
