Center caps fit American Muscle bullitt rims
Old 08-15-2011, 05:36 PM
AMDanBailer
Former Sponsor
AMDanBailer's Avatar
^^Jazzer, thanks for keeping up with this and getting his questions answered.
OP, Jazzer is 100% correct in his advice/directions for swapping over the centercaps.
Trimming the factory caps 1/32" would be very easy and could be accomplished with either a dremel tool or a razor blade.
Either that or you could remove the "emblem" on the stock centercaps and transfer it over, like Jazzer had explained.
I personally think it's a whole lot easier to trim the centercap slightly to make it fit.
As Jazzer previously stated, some of the factory centercaps are also "too deep" and may require the legs to be shortened slightly as well.
AMDanBailer is offline
Old 08-15-2011, 07:16 PM
08 Pony Package
08 Pony Package's Avatar
The stock caps have tabs on the inner diameter that snap into the 2 1/4" hole. I do not understand how I can trim those with a dremel tool.
I do understand what Jazzer was saying about peeling of the decal and trimming it...but again, not sure how to trim the inner diameter.
Thanks
08 Pony Package is offline
Old 08-15-2011, 08:16 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Just glue the Ford emblem onto the aftermarket wheel cap and let it dry. THEN, use a razor blade up along the side (like a shark fin) and just slice along the edge. I don't even think you will need to, as there will only be 1/32" overlap and about the size of the gap around the cap to the wheel hole.
Jazzer
Jazzer The Cat is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
DJ Piner
09-30-2015 03:03 PM
Mustangmalo
09-14-2015 10:23 AM
AMAlexLazarus
AmericanMuscle.com
09-02-2015 08:59 AM
Quick Reply: Center caps fit American Muscle bullitt rims
