Pothole strikes again!
Old 04-24-2014, 06:55 PM
steev
steev's Avatar
Default Pothole strikes again!
A pothole ravaged my rear right tire. Leaving me with a flat on the NY Thruway this evening.
I'm on the space saver for the moment, but the wheel itself looks true still.
What can I do now though? Can I get away with replacing on tire or do I have to do them all? They have around 20,000 miles on them and are Toyo Proxes.
steev is offline
Old 05-25-2014, 09:41 PM
Mr Nice Guy
Mr Nice Guy's Avatar
Could do two new tires to keep it balanced or if there is a lot of tread left and you aren't staggered put the new tire on the front. You just don't want two tires of different diameter ie. one new one and one significantly worn one on the rear since it would be bad for the diff. Same reason you don't want to run a donut on the rear if it is smaller diameter.
Mr Nice Guy is offline
Old 05-27-2014, 06:29 PM
need4speed
Former Sponsor
need4speed's Avatar
Hey steev, As long as you keep the tire specs the same on the individual axles their should not be much of an issue. The only nuance would be that when in comes to rotating tires or buying a new set you would have to take into account the different tires on the particular axle.
need4speed is offline
Explosive
10-02-2015 07:45 AM
WRXtranceformed
06-09-2006 12:11 PM
allfyre
08-30-2005 08:10 PM
FWP!
25
08-24-2005 11:03 PM
Quick Reply: Pothole strikes again!
