Out of round tires??
Old 08-26-2014, 09:28 AM
Daleford
Daleford's Avatar
Default Out of round tires??
I have had a shake in the front end of my car that the tire shop can't seem to eliminate with a wheel balance. They have balanced off the car and a fine tine balance on the car. Finally they say the problem is the RH front is out of round. I jacked the car up yesterday and used a micrometer with a spring loaded pointer. The RH is out 55 thousands. The LF is out 30 thousand. [Wrapped 2 layers of duct take around the tire at the center tread to provide a smooth surface to measure from]
There is virtually no side to side movement. It is all up and down which you can actually see in the RH tire as it rotates.
Is this amount excessive?
Daleford is offline
Old 08-27-2014, 06:54 PM
kennebell92conv
kennebell92conv's Avatar
Have them road force the tires if that don't work time for two new front tires
kennebell92conv is offline
Old 08-27-2014, 07:20 PM
Daleford
Daleford's Avatar
Sorry, but what do you mean by road force the tires?
Daleford is offline
Old 08-28-2014, 10:48 AM
kennebell92conv
It puts a force on the tire when balacneing . Go to tire shop and ask them to do it for you thay will no
Old 08-31-2014, 12:20 AM
jeffo
jeffo's Avatar
Default out of round
Ok,
A couple items you should do.
1. Assure the tires both have a lateral and radial runout under .028. Do this with the Hunter GSP9700 machine.
2. On the same Hunter machine, make sure your tires have a roadforce under 30lbs.
3. When balancing do a smart match which lines up the high and low points of the tire and wheel.
It will probably cost you around $40 to dismount it then remount it correct. all tires are not perfect and very few wheels are. Hope this helps.
jeffo is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
marc954
09-29-2015 11:18 AM
Quick Reply: Out of round tires??
