Tire Pressure Monitoring Systems
Old 07-03-2008, 07:41 AM
  #41
Norm Peterson
Norm Peterson's Avatar
Default RE: Tire Pressure Monitoring Systems
We"ve been through the N2 discussion once or twice here at MustangForums, and the best comment that I can give for using it is that there"s nothing wrong with doing so if you look atthis as a pure luxury item. For the vast majority of people, their driving conditions,and their cars (as opposed to vehicles such as over-the-road 18-wheel trucks), the practical advantages are almost nonexistent.
Personally and as an engineer, I wouldn"t waste the $, and many (most?) N2 stations do not evacuate the air that"s already in your tires in order to get the N2 percentage up high enough to see any benefit at all. Air is 80% N2, benefits of N2 inflation are generally said to start at somewhere around 95% - about the purity that most commercial N2 equipment is capable of producing.
These discussions have also appeared over on an engineering forum that I belong to. Usually such threads are administratively removed as being sales pitches by pro-N2 entities that do not contain any technical merit or request for technical assistance.
Norm
Norm Peterson is offline
Old 07-09-2008, 01:25 PM
  #42
tllomag
tllomag's Avatar
Hican someone explain the PVC option?
Thank you.
Tom Cavallo
tllomag is offline
Old 07-12-2008, 10:46 AM
  #43
rmcc1951
rmcc1951's Avatar
HI
I BOUGHT ATRAINING TOOL ON E-BAY, I JUST USED ITON MY O7 GT WORKED GREAT. IF YOU ARE GOING TOKEEP THE TPMS YOU NEED THIS TOOL.
BYE
rmcc1951 is offline
Old 07-12-2008, 05:48 PM
  #44
Norm Peterson
ORIGINAL: tllomag
Thank you.
Tom Cavallo
You"ll have to use an advanced Google
Something like "PVC site:www.mustangforums.com" ought to find something.
I don"t know how well that "work-around" actually works and haven"t tried it myself. Basically, you"re trying to "fool" the system with a constant pressure container.
Norm
Old 07-29-2008, 07:52 AM
  #45
Stang 07
Stang 07's Avatar
So, if i rotate my tires, Will I need to retrain the TPMS????
Stang 07 is offline
Old 07-29-2008, 11:05 AM
  #46
colin@tirerack
colin@tirerack's Avatar
Nope, you don't need to retrain them.
colin@tirerack is offline
Old 10-15-2008, 06:14 PM
  #47
P71Vic
P71Vic's Avatar
sounds like its not worth the pain in the *** to have on a car.
P71Vic is offline
Old 04-15-2009, 04:51 AM
  #48
Barnavis
Barnavis's Avatar
Hi, I am new owner mustang car. but I need you suggest about pressure monitoring systems.
thank you for your help.
Barnavis
mustang equipments
Barnavis is offline
Old 07-20-2009, 09:32 PM
  #49
Twstones
Twstones's Avatar
Default 2010 GT 18" wheels on 2009
I put new take off tires and rims from a 2010 Mustang GT on my 2009 convert. (They really look great) Old tires/rims were 16", new tires/rims are P235/zr50 18's. Both sets have TPMS already in the wheels. I plan on leaving new wheels on years around, and sold the old set with the TPMs still in the tires. Whereas I figured this would be a one time deal, I went to the Ford garage to have them reset the monitors. They said it would only take a few minutes, and wouldn't even charge me for the service. A few minutes later the mechanic came back and said he couldn't do it. Supposedly Ford changed from the rim/strap style TPMS to a type that's built into the value stem. First, is this true, or were they just trying to blow some smoke up my hinnie. They also claimed the 2 different systems were non-compatible. I could get the old one's out of the other tires, reinstall them in the new tires, but this would really be a pain in the fanny. If all the above is true, what alternative do I have to "pushing the reset button" on the info monitor every time I start the car. ANYONE GOT A SOLUTION OR WORK-AROUND?? What's this pvc thingy a few people are talking about. Any help would be greatly appreciated.
Terry
Twstones is offline
Old 11-09-2009, 07:48 PM
  #50
Xeremeh
Xeremeh's Avatar
I have a 2008 GT, which has the TPMS, and I was wondering if there was any way to link it to my head unit screen in order to display the tire pressures? Has anyone heard of this?
Xeremeh is offline
Quick Reply: Tire Pressure Monitoring Systems
