17X10 deep dish with 3.16in lip
does anyone know how far these would stick out of the fenderwells? and what kinds of problems could i run into on a 1990 lx.......? if its gonna stick out very far i will just go with the 17X8 ( i shouldnt have any problems with those should i? i would really like to see a foxbody with some 17X10 deep dish rims if anyone could come up with a pic
RE: 17X10 deep dish with 3.16in lip
The best way to figure this out, would beback-spacing. Check the distance between the mounting surface of your existing wheel, compare with the new wheel, and do the math. You will be a tight squeeze to fit them on a Fox Body Stang, but hear 10" wheels will fit. You may have to rotate the damper shock 180 degrees for clearance. You will have no problem running 17" x 8"s as I did on my '85 GT for many years. Had no rubbing issues and wished I had gone wider []
Post your request for pics in the 5.0 section of MF's and sure you will find some pics.
Jazzer
Jazzer
09-24-2015 09:18 PM
09-10-2015 08:39 PM
