Set of four 17s off a 2006 Mustang (GT?)
Set of four 17" factory alloy wheels with PZero Nero 235/55-17ZR tires:
I believe these wheels / tires will fit 2006 through 2009.
Are they from a 2006 GT, and will they fit any other cars without requiring any alterations to the car?
Looks like you have an Audi Quatro and cannot tell you the first thing about fitment of the above wheels to your ride, but can tell you this..
The above Mustang wheels are 5x4.5" bolt pattern or 5x114.3" and likely have an off-set of +30mm. I will not guarantee such an off-set, so you need to confirm it. You will also need to confirm you can run a 235/55/17" tire on your ride as the diameter is 27.2" tire. That is a pretty tall one and, as I recall, the Quatro is relatively small ride, so you may be in trouble there too.
Do some research, but don't have high expectations myself, sorry
Jazzer
Jazzer
Nowhere in my initial post do I address the matter of fitting Mustang wheels to my Audi; I simply asked about Mustang applications. Any thought of such an application would be a leap on the reader's part.
The wheels are Ford factory part 6R33-1007-DA, 17 x8.0J x 46mm, and I believe they were stock on a 2006 Mustang GT, but I have been unable to confirm the exact application.
I had been hoping to get that information here . . .
Just by reading the your original post, I would have made the same assumption as Jazzer, that you were wanting to know if it would fit other makes and models (and an Audi was a logical choice to believe you were asking about since you felt the need to include it in your information). So instead of being pissy about his response because you didnt get the information you wanted, maybe you could have clarified what information you were seeking.
My wife drives an Audi, please stop perpetuating the stereotype that all Audi drivers are snobby azzes. She would appriciate it. Thanks!
Good start eelpie!
NTO_GUY
12-24-2015 11:23 AM
1996, 2006, 6r331007, 6r331007ca, 6r331007da, ad, bolt, eelpiemindspringcom, fit, ford, gt, mustang, pattern, set, wheels
