standard tire size?
Old 08-16-2009, 09:54 AM
jgordon
jgordon's Avatar
Cool standard tire size?
hi everyone.i have a 2001 mustang gt,in the glove box the label only show's tire size as 15inch or 16inch,but the mustang gt came standard with 17inch wheels,what gives?
jgordon is offline
Old 08-16-2009, 02:47 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Sounds like Ford just put the wrong sticker in the glove box. You will have to go off of the pressure numbers on the tires you have. Many times tires are no longer OEM by the second set, so that sticker is pretty much useless by then anyway.
Jazzer
Jazzer The Cat is offline
Old 08-17-2009, 10:37 AM
colin@tirerack
colin@tirerack's Avatar
The non GT models used those sizes. You may also want to look at your doorjam to see if the 17" size is listed on the placard.
colin@tirerack is offline
Old 08-17-2009, 01:55 PM
jgordon
jgordon's Avatar
i don't see anything about tire size on the doorjam,the gt did come with 17 inch tires,right?
jgordon is offline
Old 08-17-2009, 03:29 PM
colin@tirerack
yes, the GT does
11-10-2015 11:39 AM
10-05-2015 06:07 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 06:25 PM
09-03-2015 07:14 PM
Quick Reply: standard tire size?
