hight and low offset GodSpeed wheels..
Old 03-24-2010, 07:01 PM
plo_luv
plo_luv's Avatar
Default high and low offset GodSpeed wheels..
hi all, i am buying godspeed omega wheels for my 98 cobra, they only have the high offset for 18" x9&10 withch is +42. now what i need for my car is the low offset +24, thy tell me with a 1/4" spacer it will work and the offset will be +24... is that right?????
plo_luv is offline
Old 03-25-2010, 12:25 PM
plo_luv
plo_luv's Avatar
ANYBODY...
plo_luv is offline
Old 03-26-2010, 06:38 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
The standard off-set for a 10" wheel on an SN95 is going to be +24mm. That would be a bit over 3/4" less than the wheels you propose. That would mean runing a spacer of at least 1/2" to avoid rubbing on inside/back wall of fenders.
I would not run this much spacer without installing new longer/stronger lug-bolts to support them. I have done so and would recommend you have the axles removed and longer studs pressed in via machine shoppe. This is a good time to update/upgrade the rear end fluid and replace the axle seals as well.
Jazzer
Jazzer The Cat is offline
Old 03-27-2010, 03:51 PM
plo_luv
plo_luv's Avatar
THX Jazzer!
plo_luv is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
TCStangerv6
10-11-2015 05:57 PM
gagemcc
09-22-2015 09:43 AM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
Quick Reply: hight and low offset GodSpeed wheels..
