Which tire size for my drag car?
Old 08-06-2014, 12:49 AM
Allons-y
Allons-y's Avatar
Default Which tire size for my drag car?
I'm tire-hunting for my soon-to-be drag car. The car is a 1989 5.0 Mustang LX, and it has the stock wheels on it. I don't intend to modify the body for bigger tires, I was just wondering what the best tire size and brand are for my car.
Allons-y is offline
Old 08-06-2014, 10:30 AM
88 orangepeel notch
88 orangepeel notch's Avatar
I run a set of Weld big and littles for the track. My back rims are 8" wide with 8" MT ET Drags. No figment problems at all. Rims are 4.5 backspaced, but a 5.5 backspacing would allow a 10" slick. My car is also lowered 1.5" in the rear.
Are you looking to run slicks or drag radials? On stock or aftermarket rims? Swapping from my street tires to the Weld setup saved me 85lbs rotating weight. That's noticeable when driven.
88 orangepeel notch is offline
Old 08-06-2014, 07:39 PM
Allons-y
Allons-y's Avatar
I'm going to run slicks on stock rims
Allons-y is offline
Old 08-07-2014, 11:13 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
26x8.5" slicks on the stock rims... Hoosier seems to make the best ones. That said, you should seriously consider upgrading the suspension to work with the slicks.
UPRSharad is offline
Old 08-08-2014, 02:30 AM
Allons-y
Allons-y's Avatar
Same size for front and rear? Or can i just cheap out on the fronts without there being much of a performance penalty?
Allons-y is offline
Old 08-08-2014, 07:08 PM
UPRSharad
Former Sponsor
UPRSharad's Avatar
for drag racing? You can run something like a 205/65-15 on the stock rims.
Old 08-09-2014, 12:27 AM
bluebeastsrt
bluebeastsrt's Avatar
I recommend Micky Thompson drag slicks out back. 26X8.5 for your stock wheels and yes you can use your regular wheels and tires on the front.
bluebeastsrt is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
Milan Dragway
08-12-2015 03:43 PM
mustangsrforever!!!
08-06-2015 12:04 PM
Quick Reply: Which tire size for my drag car?
