20" or 19"
20" or 19"
I was wondering which one has a more comfortable ride to them.
Cause i'm going back and forth between the two and I figured I'd make a post and see what ya'll say and see if that helps me finally pick one.
Although 20's look great and I run them personally, you will get a slightly better ride with the 19's.
That being said, with a quality tire and suspension, the difference is so minimal that I would go with what you like better in regards to looks and tire selection.
Hope this helps!
-Will
Hey evil,
Hope this helps!
-Will
Hope this helps!
-Will
Any chance you can tell which tire you recommend ?
Personally, I am a huge fan of the Mickey Thompson Street Comps for a Daily Driver looking for a great, reasonably priced street tire and I run them personally. The Nittos are also one of my favorites and there are a few others on the list.
That changes when we move onto a weekend warrior/ drag strip or road course car.
Shoot me some more info on your build and we'll get you outfitted with some tires!
-Will
Its mainly going to be my dd and something for me to have alittle fun in when the wife isnt with me. As far as parts here is what I will be getting in Sept. or Oct.
FORD RACING IRS RING GEAR AND PINION SET - 3.73.1 RATIO
Roush CAI
ACCEL SUPER COIL ON PLUG KIT
MBRP RACE CATBACK EXHAUST W/ H-PIPE- STAINLESS STEEL
FORD RACING REAR SUB FRAME KIT
FORD RACING ASSEMBLED HANDLING PACK
LAGUNA SECA STYLE HYPER BLACK WHEEL - Front 19X9 Rear 19X10
And depending on how much of a discount I get from the discount code once I hit 50+ post.
I might try to get a few more mods added to that list since i'm ordering all this from ya'll at americanmuscle.com
And thats only the first round of mods
Roush CAI
Roush CAI
Roush CAI
I received and replied to both of your PM's and would love to help you with your build.
Let's turn this beast into a monster!
-Will
Great question! To go 3.73's in your 'Stang, you would need the Ford Racing Traction - LOK Limited Slip IRS Differential, along with Ford Racing IRS Ring Gear and Pinion Set - 3.73.1 Ratio and finish it off with Axles, oil, bearings (depending on mileage) and you should be good to go!
Unfortunately, swapping from the 3.15's is not easy.
Is that something you're interested in doing soon?
-Will
