Widening rims - will it fit?
Old 02-13-2016, 06:31 PM
doctorpimp
doctorpimp's Avatar
Default Widening rims - will it fit?
2010 GT lowered on Steeda Ultralites.
Right now I have 20x8.5" +40mm offset and 6.288" backspacing.
I want to widen the rears only to 10" and run 295/35 20
Weldcraft will widen the rim, adding 1.5" to the inside of the centerline. These rims aren't made anymore and I'm having a hard time finding 20x10 used. It will be cheaper to widen these ones instead of buying a whole new set
Anyway, offset will increase to 59.5mm and backspacing to 7.788"?
Is my math correct?
The outside of the rim should stay exactly where it is now, just the inside of the rim will move in by 1.5"
I measured and it looks like I have about 2" clearance now...
Anyone running 7.8" or so backspacing?
doctorpimp is offline
Old 03-17-2016, 01:58 AM
84CopperGT
84CopperGT's Avatar
Is my math correct?
If you want the easiest answer, back up on ramps and check to see if you have 1.5 inches of clearance currently. It most likely wont work
84CopperGT is offline
Robertatl123
02-25-2016 02:55 AM
doctorpimp
02-16-2016 04:55 PM
jrylander1
02-13-2016 11:47 AM
J Leopold Kopack
Suspension
02-12-2016 11:30 AM
GingerCobra
02-09-2016 11:38 AM
Quick Reply: Widening rims - will it fit?
