help - MustangForums.com
Wisconsin Regional Chapter Chapter President: mstngsule68
Old 12-23-2013, 04:47 PM   #1
maddog06
Default help
I resently purchased a 69 mustang coupe original 6 cylinder 3sp car. I am the 4th owner and the 2nd owner installed a 302 with a c4 automatic. The person i purchased the car from got a 4 sp toploader, bellhousing and zbar all 69 vintage. I purchased the frame side and engine side pivots for the zbar from cj pony. I bolted the bellhousing to the engine but found that the engine side pivot is about 3 inches to far back from the frame side pivot. I dont know what the problem is and hope someone can help me out. The frame side has 3 holes in the frame and only the very front and 2nd one have threaded inserts in them the back one is just a hole. The motor mounts are energy suspension mounts and the drivers side has the long part of the mount to the rear. The pass side has the long to the front. I tried to change how the mounts went but they will only bolt up one way or the mount hits the oil pan. Please help someone.
maddog06 is offline   Reply With Quote
