XFORCE Bolt-On Exhaust Systems for Ford Mustang 2015-current
XFORCE is one of Australia’s top exhaust system manufacturers and now they’re bringing their products – including their famous VAREX™ Mufflers – stateside.
XFORCE focuses strongly on research and development which ensures that our diverse range of exhaust products are of powerful engineering precision, stylish and practically designed to maximize performance and most importantly, technically. Our focus on innovation and extensive quality control enables us to provide you with outstanding performance values when it comes to your exhaust. XFORCE is heavily involved in continuous research and development that combines powerfully with their manufacturing advantage in exhaust production and automotive engineering. Their exhaust systems are specially designed and dyno tested by their state-of-the-art Dynapack Evolution 3000 chassis dynamometer machine, for proven maximum performance in the R & D centre in Australia.
WHAT ARE VAREX™ MUFFLERS?
VAREX™ mufflers combine both the design technology of the stock muffler and the performance muffler into one single compact unit. A sophisticated butterfly valve mechanism is implemented to redirect the exhaust gas flow and vary be-tween the two. For higher sound level, the exhaust flows are directed through the opening path and produces maximum power with a robust sound level (or the “sports car note”) and near-zero resistance.
• Easy Installation, no hard-wiring required (in-car 12v socket included) for plug and play functionality
• Durable construction with water resistant plugs
• Dual mufflers control harness available
• Stylish remote key pad
Street Mode: Setting your Varex™ muffler in ‘Street mode’ enables lower sound levels and maximum discretion, as exhaust gases are directed through a chambered path as would a ‘stock’ muffler
Race Mode: For greater power output and sound level, exhaust gases are directed through the opening path and produce maximum power with a robust sound level (or the ‘sports car’ note) and near-zero resistance
In between: As the angle of the valve is infinitely adjustable, it can be adjusted to stop at any point between sports mode and silence mode. This gives you further freedom to set the optimal sound level according to your desired preference.
For more info about Varex mufflers go to http://www.xforceusa.com/products/varex-mufflers
FORD MUSTANG 2015-CURRENT V8
1"7/8 STAINLESS HEADER AND 3" METALLIC CATS
These stainless steel headers are more than just a pretty piece of fabrication. They increase the performance of your engine by extracting the air more efficiently into the rest of the exhaust system. The performance cats will also minimize restriction of the air flow.
Suits: FORD USA MUSTANG GT 5.0L 2015-
Part No.: HS-FM15-KITB
RRP: $1,099.00
Product Type: Headers & Cats
FEATURES: 1"7/8 Tuned-length Headers, Dual 3" 100Cell Metallic
1"7/8 STAINLESS HEADER AND 3" METALLIC CATS AND TWIN 3" CAT-BACK SYSTEM STAINLESS STEEL WITH VAREX MUFFLERS
Upgrading the engine-baclk kit to include our infamous VAREX Mufflers allows you to control the performance and sound output of your car. A simple push of the button can change your car from a light purr to a ground-shaking roar.
Part No.: XF-ES-FM15VMK-EBS
RRP: $2598.00
Product Type: Engine-Back System
FEATURES: 1"7/8 Tuned-length Headers, Dual 3" 100Cell Metallic Cats, Twin 3" Cat-Back System, Oval Center Muffler, Round Rear Varex Mufflers, Dual 4" Tip.
TWIN 3" ENGINE-BACK SYSTEM STAINLESS STEEL
A complete kit from the engine to the tips, it’ll deliver a significant increase in horsepower as well as an exhaust note that’s second to none.
Part No.: XF-ES-FM15-EBS
RRP: $2198.00
FEATURES: 1"7/8 Tuned-length Headers, Dual 3" 100Cell Metallic Cats, Twin 3" Cat-Back System, Oval Center Muffler, Dual-angle-cut 4" Tip.
A performance and sound upgrade that won’t break the bank. The cat-back system not only sounds incredible, the stainless steel finish will compliment your Pony’s rear end perfectly.
Part No.: XF-ES-FM15-CBS
RRP: $1099.00
Product Type: Cat-Back System
FEATURES: Twin 3" Cat-Back System, Oval Center Muffler, Round Rear Varex Mufflers, Dual 4" Angle-Cut Tips
STAINLESS STEEL TWIN 3" CAT-BACK SYSTEM AND VAREX REAR MUFFLERS
Upgrading the cat-back system to include our infamous VAREX Mufflers allows you to control the performance and sound output of your car. A simple push of the button can change your car from a light purr to a ground-shaking roar.
Part No.: XF-ES-FM15VMK-CBS
RRP: $1499.00
FEATURES: Twin 3" Cat-Back System, Oval Center Muffler, Round Rear Varex Mufflers, Dual 4" Tip.
WHERE TO BUY: www.xforceusa.com/where-to-buy
If you have any questions please feel free to send us a PM or visit our website www.xforceusa.com for more info.
