GT Grille and Switch Question
Old 10-05-2006, 03:43 PM
xzo6
xzo6's Avatar
Default RE: GT Grille and Switch Question
I have a new black front bumper cover from my 2006 GT...No lights or grill.Reasonable.I am near Toronto Ont.Canada..Asking $200.00 US You pay shipping.PM ME.I removed it for a 2006 Roush cover.Less than 2000KMs. Perfect piece.
xzo6 is offline
Old 09-28-2007, 11:22 AM
157dB
Cut & Paste Expert
157dB's Avatar
http://img505.imageshack.us/my.php?image=img2985si1.jpg
http://img250.imageshack.us/my.php?i...adlighthe2.jpg
157dB is offline
Old 08-18-2011, 09:15 PM
48prerunner
48prerunner's Avatar
Originally Posted by afixer
i have recieved a few ims regarding this. here are some items to answer the questions.
1. the blue wire ( # 87 on the relay also output to the fogs) i have added is just if you are using the gt switch. that sends current back thru the harness and turns on the led in the gt switch when the fogs are on. so if you are using a toggle it is not needed.
2. the included pdf is of the factory fog wiring on the gt. note! that the switch uses grounds to trigger relays not hots. so if you are hooking to the stock or gt switch know that it is for a ground to trip the bosch relay and not a hot! so look close on the digram i drew.
http://www.2005stang.com/gallery/alb.../foglights.pdf
Ive read so many of these posts tonight I think I read one where Afixer is in Canada doing a movie until oct but at this point not even sure if that was this year lol. The link for the diagram doesnt work I found this on another forum http://www.mustangcollective.com/sho...adlight+switch
Sorry not enough time to copy the image id hope the link is ok
Anyhow If I'm using the street scene wire harness with the gt switch do I just hook the yellow wire up to the gt switch and Im good or is there more to it?
Ok may have found the info i needed
http://www.mustangcollective.com/sho...+switch+wiring
and
48prerunner is offline
Old 08-20-2011, 03:18 PM
48prerunner
I got them hooked up last night just waiting for gt headlight switch to get here. I hooked up the rocker switch temporary for now. Biggest thing everybody talks about the green or yellow wire. Street scene put like 5 inches of yellow wire on end of green wire you just cant see it cause its under the wire loom.
Old 09-18-2018, 05:46 PM
08'MustangDude
Banned
08'MustangDude's Avatar
ALL these links are bad...
08'MustangDude is offline
Alec
10-04-2010 03:01 PM
Red Beast
06-09-2009 06:15 PM
Texcan
07-29-2008 11:45 AM
mpatilla
01-14-2008 02:57 PM
1slow67
10-17-2007 10:50 PM
Quick Reply: GT Grille and Switch Question
