help!!!!! serious question concerning brakes
RE: help!!!!! serious question concerning brakes
Here's a link to a picture of the left (driver's side) brake caliper on my Mustang. There are no visible numbers. The numbers are most likely on the back. The rears are substantially different in appearance.
http://i28.photobucket.com/albums/c2...t/DSC04969.jpg
Hope that helps. Sunday is a bad day if you need to contact a Ford dealers parts department. You might try Pep Boys, Auto Zone, or one of those outfits who have OME catalogs.
There may also be torque specs for the caliper mounting bolts. You may want to check this out with your dealer, or invest in a Mustang shop manual, not the after market ones, but the one from Ford. Price will be somewhere around $170, but it's worth it if you are really going to be digging into your Mustang. There is also a parts catalog for about the same amount, which can save you some grief as well.
well i got them on and they work so... i guess it is just a number for tracking purposes? i couldn't see a difference so i just went with it. anyways, here is a pic... Thanks for all the help
[IMG]local://upfiles/48992/645E9E222BDD4CEA8697C591735C2189.jpg[/IMG]
[IMG]local://upfiles/48992/3A9C31DAF6B346E1A4D193B977517824.jpg[/IMG]
ORIGINAL: Pyrat
Mustang Brake Specs
Front
GT 316 (12.4 in) x 30 mm vented disc, twin-piston 43 mm floating aluminum calipers
V-6 293 (11.4 in) x 30 mm vented disc, twin-piston 43 mm floating aluminum calipers
Rear
GT 300 (11.8 in) x 19 mm vented disc, single piston 43 mm floating iron calipers
V-6 300 (11.8 in) x 19 mm vented disc, single piston 43 mm floating iron calipers
According to this the fronts are aluminum and the rears are iron. Can you determine which two are aluminum and which two are iron?
Mustang Brake Specs
Front
Rear
ORIGINAL: 8cd03gro
wow we actually have larger rear brakes? i've never even heard of that...
ORIGINAL: Pyrat
Mustang Brake Specs
Front
Rear
Mustang Brake Specs
Front
Rear
for drifting nah mean
ORIGINAL: 8cd03gro
ORIGINAL: Pyrat
Mustang Brake Specs
Front
Rear
Mustang Brake Specs
Front
Rear
mungodrums
10-07-2015 04:01 AM
09-03-2015 07:14 PM
