Removing Aftermarket Wing
RE: Removing Aftermarket Wing
heat it up with a heat gun or hairdryer to soften the tape. I actually have a plastic chisel that I use to scrape things like that off. The plastic won't hurt the clear cote and once you get it off, use Goo-Gone to remove the rest of the adhesive from the paint. Goo-Gone won't hurt the paint either, I think it is orange based. A little rubbing compound to take out the light scratches you might have made, and you'd never know it was there. You may also be able to saturate the joint with Goo-Gone and wait about 10-15 minutes and pull it off. It will probably be a litte tough, but it should come.
jwog666
12-27-2021 08:09 PM
09-24-2015 09:18 PM
