advice needed guys
advice needed guys
been looking around on e-bay saw some things id like to add to my stang. who makes the nicest and best quailty 1/4 panel scoops and clear front turnsigal lenses?? also intrested in seq. turnsignal kit.
let me know your goodexperiances from e-bay products and the ones to avoid
thanks for ur help
thanks for ur help
RE: advice needed guys
Those louvers look good, RYD PNY. Oldtimer Stanger, I definitely think those Silverhorse flush-mount louvers (like on ryd's stang, and many others on this forum) are the cleanest looking option there. Although they are a bit of work, because you have to remove the rear quarter window. Do a search on them and you'll see a bunch of discussions and pics for them. Do you like the flush-to-the-body look, or the big louvers that stick off the side of the car? Cervini's has got some big scoop louvers for the old-school Eleanor look.
ryd, what tint % are you using?
http://www.meter4it.com
IMO those are the best ones out there. Bit more difficult install then others but much better quality.
There are plenty of scoop makers. Quarter window or panel. I like Cervinis and am in the painting stage right now. Look at a search engine like dogpile.com and punch up mustang parts or scoopsetc. and that will get you into different companies. Look at what you like best. Most will take some sanding to get perfect but that's normal.
ORIGINAL: raubt
http://www.xtreme-tint.com/ I went with the Dark on the rear and Medium on the side front
I installed the louvers in 45 min. with a friend from a glass co.
