45mm offset for front wheels?
thewheels I want to buy are on backorder from the manufacturer. the 18x9's are on backorder but he has 18x10 in 45mm offsetin stock. these are for the back but would they fit up front also
RE: 45mm offset for front wheels?
I know Roush has 18x10's on the front and rear, but I believe the offset is 41mm so I'm not sure if45mm will work cause I'm not very knowledgableabout tires but its as if the measurement damn close, I mean a 4mm difference doesn't seem that much.
do what I did and order the 2 rear put tires on the and put them on front and try them, if they work order 2 more. I have 20x10 on the front of mine so there is alot of room in there.
My stock 18 x 8.5's had a 50mm offset and had the stock 235/50/18 tires. I just installed 18 x 9.5's with 47mm offset and 275/40/18's and there's no rubbing.
Galactic
04-29-2019 02:56 PM
maestro1024
09-21-2015 02:40 PM
