Need help selecting "drag wheel/tires"
I am looking for an old school drag car look on my 2008 black bullitt. Big thick rubber out back and not skinnies but narrower tires up front.
Here is what I was thinking....
Wheels
http://www.americanmuscle.com/chrome...8x9-18x10.html
18 X 9 up front and 18 X 10 out back
Rear Tires
http://www.mickeythompsontires.com/s...ETStreetRadial
3786R
P305/45R18
29X11.50R18
32
R2
9.5-11.0
10.3
28.8
91
3786R
P305/45R18
29X11.50R18
32
R2
9.5-11.0
10.3
28.8
91
Front Tires
http://www.tirerack.com/tires/tires....es&place=0
245/55ZR18
Load Index 103 = 1929lbs (875kg) per tire
Speed Rating “W” = 168mph (270kph) 103W SL
Treadwear: 400
Traction: AA
Temperature: A400 AA A
1929 lbs.
44 psi
9/32"
32 lbs.
7-8.5"
8"
9.9"
NA
28.5"
724
I'm interested in hearing comments on whether these tires will rub and how they'll look. Would like to see pictures if anyone has a similar set up. Thanks!
Wheels
Rear Tires
3786R
P305/45R18
29X11.50R18
32
R2
9.5-11.0
10.3
28.8
91
3786R
P305/45R18
29X11.50R18
32
R2
9.5-11.0
10.3
28.8
91
Front Tires
245/55ZR18
Treadwear: 400
Traction: AA
1929 lbs.
44 psi
9/32"
32 lbs.
7-8.5"
8"
9.9"
NA
28.5"
724
RE: Need help selecting "drag wheel/tires"
Idon't see any issues with that set-up and the S197.
Saleen runs 275/40/20's out back and car is lowered about 1.5'. That tire is 28.4' diameter and your proposed tire is about 3/8' larger. Remember, that only 1/2 of that overall diameter will translate into clearance issue and the other 1/2' into ride hight. I know several that run 305/35/20's and have no issues and your MT's are slightly narrower.
I say Go For It!!!!
I say Go For It!!!!
xbmx89
Texas Regional Chapter
11-10-2015 10:43 PM
