Fog lights bulb...
Fog lights bulb...
Hello, I am thinking of converting my fog lights to HID. I am a bit confused about the type of bulb there is inside? Some info says H10 some says H11. Could anyone help? Also, any info from those already converted their main or fog lights to HID will be very much appreciated...
GT'06 vert
GT'06 vert
If it were me I wouldn't do it! You are asking for trouble. Depending on the type and design of what you install, may screw up your fogs. There is a post of a guy in the main section that is having all sorts of problems with his HID setup https://mustangforums.com/forum/2005-2014-mustangs/471097-fog-light-housing-keeps-burning-up.html. Don't get me wrong, I'm sure there is a setup that may work. Just be sure you do your research and select the right one. I'm sure someone will chime in on this. Again, don't just buy any setup as it may cause you alot of grief!!
The GT's have H10's. I prefer to keep the fogs functional AS fogs and have put warmer (yellower) bulbs in. They make a big difference in really dark, rain or fog conditions. Cooler bulbs (whiter) only cause more glare. Also, be aware that the stock reflector provides a fog pattern (short and wide) as opposed to a driving light (long and narrow).
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
