Made my own darn keyhole plug
I put saran wrap in the keyhole, then pressed clay into it. Then I pulled it out and then baked the clay. Once it was dry I sanded it to the proper shape. Then I made a silicone mold of the part. Then I poured liquid resin into the mold, casting it in plastic. Then a light sanding, primer, color and clear. 24 hours later a wetsanding and polish. Attached it with a dab of emblem adhesive.
Although I liked having a keyhole when I was installing my CAI the other day and needed to get something out of my locked car...
Seems like an awful lot of work for something that you can buy for $15. Plus, IMO its not worth the time or money to get one of those, because I don't think it improves the look all that much. Now if there was a way to replace that whole part of the handle (so that it looked like it came stock with no keyhole, instead of looking like it was plugged) that would look cool.
The guy that was selling them for $15 was ripping people off. And doing it like this means that if I ever have to, I can pop it out and get to the keyhole. Also, it's not just a round piece that sticks into any keyhole....it has to be made specifically for the car.
It wasn't hard to do, and I might take some to the Mustang Cruise here in MD and sell a few. So it was worth the 2 or 3 hours I spent. A lot of people were interested in these plugs and once I saw the idea, the look of the ugly keyhole was really bothering me.
Could you go one further and mold it with a blank key out of the back of it to facilitate mounting it instead of the emblem adhesive. It could then actually be quickly removed in a dead battery situation where you
really need ot use the key hole to get in?
Hmmm....it's possible I guess. It might be kinda difficult to get the casting perfect enough so that when the blank is in the hole the plug lines up perfectly. if I had a CNC machine maybe. Good idea though.
The emblem adhesive is very forgiving. It's not as permanent as you might think. It's a lot like rubber cement. Once you pry out the plug, you can use your key to pull out the remaining glue (once cured it is like rubber) and then you can use your key to open the door. Then just glue it back in.
Eaglestroker,
PM me if you want one. Maybe I can hook you up. I am limited on colors I can paint but obviously I have Alloy.
Cuzzo,
Thanks man....but no, no machining experience here....just what I have done to the car. Mainly just stuff like this for emblems and such.
Cuzzo,
Emblem Adhesive, also known as Gorilla Snot from its yellow
appearance, it very tough from my past experiences with it.
