Radar Detector Installation
here are a couple
I'll reach out to a few customers and see if i can get some others for you.
Works great!
For more information on our radar detectors just click below
http://www.southernmustangparts.com/...tors-c-33.html
Ken
Works great!
Ken
Both work great in my opinion.
The X50 is a lot less expensive but the 9500ix has a lot of advanced features.
Here are the links to each to compare
http://www.southernmustangparts.com/...tor-p-344.html
http://www.southernmustangparts.com/...tor-p-429.html
Ken
Any constant 12VDC source (preferably shuts off when the ignition is off) will do. If you use the dome lights, be sure first that your power source stays on AFTER the lights go out. But then you may be in a situation where the detector will stay on after you shut the car off.
For those of you that do, check this out - Very clean install!
http://www.southernmustangparts.com/...ord-p-371.html
Ken
The S197 dome lights dont work like dome lights of yesteryear.
There is switched 12V for the ElectroChromatic mirror option.
Circuit 46, Connector C919 in the headliner area, Violet wire,
Fuse 7 in the SJB, Hot in Run or ACC.
Here are a couple of pics of my hardwired radar detector. I ran the cord into my headliner, down the passenger side a pillar, and into the passenger footwell fuse box. I used either fuse spot 13 or 14, i cant remember, but you can match it up with the picture. I used the "Add a circuit" fuse adapter from advance auto parts. It plugs into a fuse spot in your fuse box and gives you a power lead off of it. You then plug the normal fuse into the other slot on the "add a circuit" and attach your radar detector hot wire to the lead coming off of the "add a circuit." Then you just attach the ground to any metal screw or bolt you like. HTH!
Anyway... thanks again.
Anyone else using a Beltronics Pro RX65? Hope it's good, cuz I just spent 2 friggin hours wiring it in.
