Radar Detector Installation
#21
http://cgi.ebay.com/ebaymotors/Blend...ht_4852wt_1165
I love the mount, works awesome and it doesn't shake around at all. I've just been lazy in wiring it to the fuse panel. I already found an empty slot to tap into for the light for my boost gauge, I'm just gonna use the same switched power point for the detector too.
whatever you do always put a fuse inline! you don't want to have a short without a fuse, your wire will turn into a heating coil and set your dash on fire
#22
that's what I'm getting ready to do. I already have my V1 mounted to the rear view mirror with this...
Oh and btw, I used the Add-a-circuit piece pictured before which adds a fuse. I have it in the Accessory Delay bay which is 5A and then I just put another 5A fuse for the accessory. No idea if that is the right fuse to have, but I figured it would be okay... thoughts?
#23
I bought mine from them, they look good
http://www.countryjoycrafts.com/350Z/escortmount.htm
you have also an installation video on the bottom of the page
#24
09-10-2015 08:39 PM
