How to: blackout rear quarter lenses for $10 on S197
Old 01-04-2009, 05:09 PM
fullboogie
fullboogie's Avatar
Default How to: blackout rear quarter lenses for $10 on S197
Here's my latest project on doing a little blackout job on my '08. I know you can buy these from a vendor, or use Niteshades, but I was bored and wanted to do this myself. So keep the comments about "But it's easier if you..." to yourself. I get satisfaction from doing things right and doing them myself. Anyway, hope this helps:
First, pop the rear quarter lens out using a screwdriver and rag. Pry on the end towards the front of the car - they pop right out. Unscrew the bulb socket and take it to the bench.
Before you can lay down the tint, you have to remove the embossed Ford emblem and part number. I used a razor blade and 600 grit sandpaper to knock it down, then hit it with the buffer wheel.
Cut out a piece of tint with about a 1/2" margin (I used 35% - anything darker did not let any light through at night), peel the backing off, spray the lens and tint with a water/soap solution, and lay it down.
Use a heat gun to shrink the tint to the lens. I used a microfiber towel and my thumb to help the process.
Turn it over, and use a razor knife to carefully trace the outline. If you're good, it will come out perfect.
I chucked the lens up in the bench vice and continued to use heat and pressure to make the tint conform to the bends. Patience is a virtue at this point. You will pay special attention to the perimeter of the lens.
This is what you will end up with:
And this is how it will look on the car. Notice my other mod? Blacked-out trunk emblem - sweeeeeet!
Goes well with the front signal lenses and blackout out pony/grill, doesn't it?
fullboogie is offline
Old 01-04-2009, 05:27 PM
1nasty05
1nasty05's Avatar
i was thinking about doing this but mine is redfire and it just kinda blends in back there so i just dont worry about it... but it looks great! good job. where did you get your taillight trim from?
1nasty05 is offline
Old 01-04-2009, 05:29 PM
zporta
zporta's Avatar
looks pretty good man...
zporta is offline
fullboogie
fullboogie's Avatar
Bought the taillight trim on Ebay. I broke the left one and need another set, but can't find ANY black trim ANYWHERE. Thanks for the comments. And you're right, this would probably only work on a black car.
Old 01-04-2009, 05:32 PM
illin
illin's Avatar
Looks really nice.
Got a how to on the rear deck emblem?
illin is offline
Old 01-04-2009, 05:39 PM
1nasty05
1nasty05's Avatar
i painted my rear emblem and it was really simple i didnt even take mine off i just masked around it and the gt in the middle and just sprayed it gloss black and used some clear coat very easy
1nasty05 is offline
Old 01-04-2009, 05:42 PM
1nasty05
1nasty05's Avatar
and there you go
1nasty05 is offline
Old 01-04-2009, 05:51 PM
AlloySixxer
AlloySixxer's Avatar
Did you do the same to the front turn signal lenses or did you buy those?
AlloySixxer is offline
Old 01-04-2009, 05:56 PM
fullboogie
fullboogie's Avatar
Same thing. Autozone tint.
Old 01-04-2009, 06:00 PM
Stkjock
Retired Mod
Stkjock's Avatar
looks good
there are overlay kits made that dont require as much effort
Stkjock is offline
Quick Reply: How to: blackout rear quarter lenses for $10 on S197
