Alloy Stangs+Black Turn Signals!!!
i will be possibly purchasing black turn signals from a member, though i'm wondering how they look on an alloy stang first.
although i was set on clear signals, i'm purchasing these off a member and the price is good, so i'm considering it.
thanks.
thanks.
Id go with the blacks, if your getting a good deal on them. take the money you saved buying used and get some stealth bulbs. However, Im probably biased..
As mentioned above, anything is better then amber.
Alloy is close to black, and here is mine with the blacked out turn signals:
And this is what the "black" turn signal looked like when first installed. I decided that the black housing with clear lens wasn't enough, and used VHT NiteShade to darken the lens:
Sorry for the hijack, didn't intend to do so.
The stripes are 18" center, 1" gap, then 1" pin stripe. The bumpers are painted, the rest is vinyl still until I can afford the new hood then I'll have everything painted. Painting the bumpers meant the license plate frame can be filled in - and since a pickup rear ended me and I had to get the work done anyway I had both front and rear bumpers painted.
