Door Panel Leather Sagging - **FIX**
Old 07-25-2018, 12:15 PM
  #251
Stormey
Default My lilí Red Pony
My lilí red pony thanks you. She sat all forlorn and alone for 4 years while I battled with cancer - I won, but my ponyís leather peeled away on both doors.
I tried the auto store stuff, very messy and didnít work, so your tutorial is looking pretty good.
Stormey is offline
Old 09-04-2018, 08:27 AM
  #252
Dutch57
Thumbs up Very happy with the result! Thanks all!
Thanks all for the very helpful information!
Both door panels on my 2006 GT had been ugly taped for several months until this past weekend. I used the original post supplies except I went with 2 small and 2 medium poly bristle brushes instead of foam brushes. They worked well and came in handy for cleaning out the dust and debris from the degraded material. Turned out great! It took less than 2 hours to complete the job, but I did check it a couple times over the next 8 hours and smoothed out any bumps in the glued panel.
The panels had come loose around the top of the armrest on both sides. This made it more of a job, but I was able to work the glue covered material into place by using a large screwdriver--a wide putty knife might of worked faster--to push it back into its original location. On the first door I didn't get it all the way in at the armrest and ended up with a little extra material at the top. I took a little more time and care on the second door and got the pane back to its original position. Fix it before it comes off around the armrest and you'll have a fairly easy job, but know that you can still fix it if it does come off the armrest. Just give yourself and extra 15-20 minutes to reseat the glued panel in the crevice around the armrest. I'd give myself a "B", my girlfriend said "A-". Seriously, looks original.
Sorry I don't have pics of the process, but here's my boy:
FrankBest car I ever owned.
Dutch57 is offline
Old 09-04-2018, 01:16 PM
  #253
8 ball
8 ball's Avatar
I tried this stuff about 3weeks ago, and itís already starting to come loose. The last adhesive I tried was the Gorilla Glue spray adhesive, and it lasted almost a year.
8 ball is offline
Old 09-07-2018, 06:25 PM
  #254
idgapny
Thanks for the post. You are right, you are not alone.
idgapny is offline
Old 09-08-2018, 05:14 AM
  #255
Otter
All I can say is I followed the original instructions using Weldwood contact cement back in 2014/2015 and,it is still fine. A friend bought the 06GT from me in 2016, still strong at 250k miles and door panels still not sagging. Car has never been a garage queen, but does have a cover.
Otter is offline
Old 09-09-2018, 09:01 PM
  #256
LowkeyGT
LowkeyGT's Avatar
Mine just started peeling, so thanks for the info.
LowkeyGT is offline
Old 01-11-2019, 06:10 PM
  #257
valsurfer101
Hey everyone, Ive been dealing with the same issue for 5-8 years. Ive had them glued on professionally and my self and it never looks as good as factory.... I was surfing the web and found that coverlay makes an insert for them and it looks great! its molded abs plastic and they paint them, if you want for free. They are $150 however I found them for $135 on eBay (came drop shipped from the manufacturer) Honestly this is how the doors should of been designed, I got min in red and ill never deal with sagging panels again. I think if you really wanted you could wrap them in letter and it would hold up better than factory. Easy to install, they have a video on their site (I only had my door panels taken off for other work, you can leave them on to do it)
There was a company that made something similar years ago wut the were in the 350-500 dollar range and not worth it Imo.... I am happy some company has a good solution.
(Please excuse my dusty doors, they've been sitting in the garage for a while) hahaha
valsurfer101 is offline
Old 01-13-2019, 12:24 PM
  #258
07 Stang
07 Stang's Avatar
Wow, they look nice!
On my doors I put door piping around the insert and it has helped hold it up.
07 Stang is offline
Old 01-19-2019, 09:09 AM
  #259
spectreman
spectreman's Avatar
Wow, that's a great find. Thanks for posting. I think I'm going to order a set.
Lee
spectreman is offline
Old 02-23-2019, 09:43 PM
  #260
edcologne
edcologne's Avatar
great info
just ordered a set, who knows how long that stuff is around.
the panels started to get loose when I sold my 2006 gt.
I did repair, glue it back on my 2009 gt/cs, looked ok but not as good as it should or was new.
now on my 2008 gt500 all looks still fine, but I rather be prepared for the likely inevitable
edcologne is offline
Mr. D
Off Topic
833
06-19-2016 02:04 AM
jerrytubes
10-23-2015 12:11 PM
b8checker
10-08-2015 12:55 PM
jrrhd73must
10-02-2015 09:17 PM
b8checker
09-30-2015 07:11 AM
Quick Reply: Door Panel Leather Sagging - **FIX**
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
