gauge cluster swap
gauge cluster swap
heyguys I tried searching but only came up with other questions including my color swaps and going from 4 gauge clusters to 6 gauge clusters.
My question:
I have a 08' GT with gauges that look like these:
http://www.allfordmustangs.com/forum...luster-003.jpg
and want to swap in a roush gauge cluster that looks like this:
http://carphotos.cardomain.com/ride_...0005_large.jpg
will this be plug and play?
How are the miles stored? on the cluster themselves or the ECU?
Basically what is needed to make these swap over easily. I plan on swapping entire clusters
My question:
I believe you need the ECU recalibrated because the Roush cluster goes beyond our stock 120mph. I know that is what happens when you reface your cluster to a Saleen where it shows 160. Curious to know about this too. Good question
The cheap way out would be to get a new gauge face. Not sure if they make them, but there are many places that make custom faces. Look around. If you don't care about the MPH going that high, then i would go that route. Much cheaper, no computer tune needed.
that that is a v6 cluister in the pic but I do have a GT and my speedo does go to 140MPH so I do not think the speedo will be off.
so basically it looks like it should work except for the milage question
here are a few links...
http://www.calmuscleparts.com/store/...CES-C3095.aspx
http://www.americanmuscle.com/simco-...edium=Shopping
http://www.andysautosport.com/ford/2...a00033923.html
http://www.speedycarparts.com/sku/Fo...=24-48836713-2
http://www.speedycarparts.com/sku/Fo...=24-48836759-2
http://www.speedycarparts.com/sku/Fo...=23-50038633-2
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
