wheels and tires
What's the width? The 18 x 8.5 can take 255's safely. But you'll need to check the specs on the tires you want. Although most tire manufacturers recommend no wider than 255's on an 8.5" wide wheel. Check the casting markings on the inside of the wheel.
Thanks!I found these:
http://www.americanmuscle.com/17x8-bullitt-black.html
but I thought the 94-04 had a different config or something from the 05+ how do they have these listed as both? Is it because 05+ will fit a 94-04 (but not vice versa) and these wheels are actually designed for my car?
09-08-2015 11:50 AM
