Agent47 Double Barrel Strut Tower Brace
Agent 47 Double Barrel Strut Tower Brace
2005-2009 Mustang GT (With Plenum Cover or Supercharger)
Free Shipping in the United States through 12/31
$249.00
This brace is very similar to the standard GT brace in that is uses chromoly tubes Tig welded to CR steel boxed structures. It is different because it uses two smaller 1” chromoly tubes bent for maximum clearance over the engine.
These boxes use all four bolts on the tower to mount the brace solidly(no joints to pivot).
One look at one of these braces and you will see the design, fit, welds, and finish are second to none. They come in a black powdercoat and install time is less than 15 minutes.
Check them out at www.southernmustangparts.com or just click below
Agent47 Strut Tower Brace
Ken
$249.00
Ken
We also have the Agent47 High Flow Upper Grills
$299.99
Agent47 Mustang Parts
Ken
$299.99
Ken
The Agent47 brace uses 2 chromoly tubes Tig welded to CR steel boxed structures. It is different because it uses two smaller 1” chromoly tubes bent for maximum clearance over the engine. These boxes also use all four bolts on the tower to mount the brace solidly (no heim joints to pivot).
I have them in stock and ready to ship if you decide to go with this one.
Thanks!
Ken
We definitely appreciate the business!
The Agent47 products are well made!!
Ken
