Anybody tried this antenna stub?
$20 and they say it screws right in. I was just googling around and found it. Anyone here tried it? :icon_google:
http://www.cravenspeed.com/products/...y-Antenna.html |
I don't have that one but I can tell you will lose reception. If that doesn't matter then you just need to know if it doesn't fit can you return it. It is a solid aluminum antenna which is what I made for mine and while it looks fine it doesn't follow the rules for antenna reception. It is not just a matter of sticking any length of metal in the air. The length of the antenna is supposed to be a fraction like one quarter of the average wave length you are looking to receive. AM had long antennas FM shorter ones. There is a proper way of making a shorter antenna by wrapping a wire of the appropriate length at the end of the shorter shaft. I assume they don't think it is worth while.
its free to cut it yourself....
...looksbetter too... |
http://www.americanmuscle.com/14inch...enna-0509.html
I have this. I personally, did not notice any difference in the radio signal. If this is too long, they have an 8 inch as well, but when i read reviews of it people were complaining about loss of radio signal so i went with the 14 inch. They also have black in 14 and 8 inch if you prefer it over chrome. Hope this helps. |
Yeah, I was planning on getting the 8 inch but figured I'd look for something shorter. I hate the gigantic factory antenna and I would love some sort of short stub like this. Or maybe one even shorter or angled back a bit. I took mine off completely when I was washing it and just left it off. I still get FM radio reception fine so I'm not too worried about it. Don't use the radio much anyway, but I'm not ready to shave it and patch the fender just yet.
Hell, I just took mine off.
Yeah, but my mind insists that there be SOMETHING there. Since I already have that damn plastic knob on top of my fender, I figure I'll do the best with what I've got.
Cut mine in half, put the ball back on, and I never noticed a difference in reception, AM or FM.
Originally Posted by BAB GT
(Post 7920759)
The real test of an antenna is how it works for YOU. Someone listening to a baseball game on an AM station 50 miles away has a different need than someone listening to a local FM station.
I haven't kept up with the sound systems, but on my car there is a test to measure the relative strength of a radio signal. Turn the radio on and tune to an AM or FM signal. Simultaneously press and hold preset buttons 3 and 6. This enters a "speaker walk-around test" that tests each speaker individually. While in this mode, press preset button 3. This displays digits showing signal strength. The higher the number, the greater the strength. You can check the relative signal strength for various antennas using this method. Turn the radio off to exit the test. I would suggest testing the various antennas with the car in the same position. Then I would suggest that you move the car and try the test again. You can sometimes get screwy results in any one given position because of the radio signal bouncing off buildings, etc. Also, unless you only have one station that you listen to, check the stations at the high, middle, and low ends of the AM/FM bands. Short antennas are notorious for having limited bandwidth. For example, they may be fine in the middle of the band, but have terrible reception at the high or low ends. |
