interior trim issues
Old 07-03-2012, 08:08 PM
Rundel
Rundel's Avatar
Default interior trim issues
I recently acquired my first Mustang, a 2007 GT/CS that was nicely modified by the previous owner. ( 6spd, aluminum driveshaft and flywheel, FRPP suspension, LCA, panhard rod, Shelby Wheels, CAI, Shelby grill and rear spoiler) Only 17k on the odometer at time of purchase.
I notice that Ford did not impregnate the charcoal black color into the plastic interior trim. Even gently bumping it will cause white spots and streaks to appear on the threhold or on the door trim or door panel. I've had O'Reilly's make me a can of matching spray vinyl dye but it doesn't hold due to the weakness of the underlying factory color.
So anyone have a tip as to how to solve this problem? Is there another coat of something that would harden the surface and protect it?
Rundel is offline
Old 07-04-2012, 12:03 AM
BleedinBlue
BleedinBlue's Avatar
Do you have any pics? This doesn't sound common at all. I wonder if the previous owner did some interior painting, and that paint is coming off...but then again white underneath?
BleedinBlue is offline
Old 07-04-2012, 06:49 AM
Nuke
Nuke's Avatar
5 years on the forum and I haven't heard that one. +1 on pics...
Nuke is offline
Old 07-04-2012, 08:39 AM
Rundel
Rundel's Avatar
right now I've got it all touched up but its only a matter of time, and ususally not long, that the threshold will get bumped and I'll photograph it then.. Its not just the threshold, kick panels, doors panels, window trim all seem to do it. I wonder if Ford assembled without the panels being properly prepped and cured but with a 6 year old car you'd think this wouldn't happen.
Rundel is offline
Old 07-04-2012, 02:12 PM
Nuke
Nuke's Avatar
Does it appear that they were a different color at one time? I believe the ones in my '07 and my wife's '06 are solid black material because I recall a deep scar in one of our trim pieces somewhere and it was black beneath the surface.
Nuke is offline
Old 07-04-2012, 04:27 PM
BleedinBlue
Same here, I've got deep scratches in a couple of spots. My interior pieces were not painted from the factory and are solid colors.
Maybe the white color underneath is primer or something. Until I see pics to convince me otherwise, I'm pretty sure a previous owner did some painting and that paint is coming off. That's not good, and messy. I'd suppose you'll have to re-paint to get it looking decent, and that's going to take a good bit of work.
Old 07-05-2012, 01:59 PM
pinn
pinn's Avatar
Sounds like the previous owner changed the interior color without telling you. Post some pics of the problem if you can.
pinn is offline
Old 07-05-2012, 02:30 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Interior plastic pieces are injection molded meaning the color is part of the plastic (impregnated). It does not flake off or 'streak'
The white you are seeing probably the damaged surface reflecting light differently. It happens on all colors but black shows it the most. Take any piece (or color) of plastic and scratch it up, it will appear lighter in color in the area you scratched.
Derf00 is offline
McLeary
03-14-2016 07:50 PM
Shawmp
09-18-2015 07:52 AM
09-16-2015 07:53 PM
MusicCity615
09-12-2015 07:05 AM
mdj89
09-08-2015 10:40 PM
Quick Reply: interior trim issues
