4-Channel Relay Remote Center
Old 07-09-2018, 05:47 PM
08'MustangDude
Banned
08'MustangDude's Avatar
Default 4-Channel Relay Remote Center
I installed a 4-channel relay center, that is remotely controlled for various
lighting I plan to add later on. I installed an LED strip on the front underside
of the hood, and wired it to CH_D of the center.
PRODUCT:
$8.00 on eBay with remote, no battery in it...
WIRING SCHEMATIC:
When I got it, the power terminal block was installed backwards:
FIX:
I will still get my money back after complaining the terminal was put in backward.
I guess they do everything backwards in China.
MOUNTED IN VEHICLE:
Power run to all "B" terminals, and the LED strip load placed on CH_D Load Terminal "A"
LED STRIP OFF:
LED STRIP ON PRESSING "D" ON REMOTE:
All buttoned up:
They also have a sound board, with nine ground terminals that takes a MicroSD card.
When you ground one of the nine pins, the appropriate MP3 will play. So, I can play at least
four sound effects remotely in conjunction with this 4Chanel relay center. Since I am using
a Starship motif, I can play related soundFX with lights I plan to add later.
DEMO
08'MustangDude is offline
Old 07-12-2018, 08:41 PM
08'MustangDude
Banned
DUSK- LED Strip On
NIGHT - LED Strip On:
NIGHT DEMO VIDEO
Night demonstration.
Hooked the Halos and LED strip to the remote relay center.
I diode isolated the Halos at the relay and car side, as they also come on with
the car ignition on.
CyprusMustang
07-03-2015 01:44 PM
need4speed
01-11-2014 09:08 PM
Nick@Autogeek
04-19-2011 07:04 AM
66$tang
13
02-12-2010 04:53 AM
snkchmr
03-24-2005 08:50 PM
Quick Reply: 4-Channel Relay Remote Center
