how much oil in the crankcase
Old Dec 28, 2008 | 07:21 PM
thuxel's Avatar
thuxel
Originally Posted by cavediver
So you never bothered to look at the owners manual to see that your Mustang uses 5w-20 and takes 6-quarts with a filter????
Canadians only read French, their manuals are in English.
Old Dec 29, 2008 | 11:20 AM
07musclemustang's Avatar
07musclemustang
Hey thuxel, I dont know how to say F#%K YOU in french or else i would. I'm Canadian and like most of the other Canadians we speak english. one province is french and one is bilingual.
Know what your talking about before you open your mouth and prove to everyone how ignorant you are.
Old Dec 29, 2008 | 11:47 AM
mcburns36's Avatar
mcburns36
Talking
I can help you say it in German.
Old Dec 29, 2008 | 03:19 PM
157dB's Avatar
157dB
Cut & Paste Expert
Just for the info, the S197 6 banger uses 5 qts with the filter change.
Old Dec 29, 2008 | 03:52 PM
pascal's Avatar
pascal
S197 Section Modder-ator
You can tell him "Va te faire foutre" or "Encule" (with the accent on the E) and you'll make a new friend
Chill man, I think he was joking, lol.
Old Dec 29, 2008 | 03:57 PM
Timspony's Avatar
Timspony
SVT Section Moderator
6 quarts with Filter FTW on a '06 GT!!! ....5w30 will hurt nothing!
Old Dec 30, 2008 | 09:58 AM
solaratomic's Avatar
solaratomic
My 01' 5.4L truck took 7.0 qts w/filter. Try a power stroke, they take 15 qts w/ a filter, the filter holds 2 qts. Helped my friend change his on his 02 7.3L and we had to have a 5 gallon bucket to drain the oil into.
Old Dec 30, 2008 | 10:05 AM
blackice05's Avatar
blackice05
6 qts according to the manual, takes a little more usually with filter change
Old Dec 30, 2008 | 10:54 AM
Norm Peterson's Avatar
Norm Peterson
6 quarts should put the oil level at the top of the "shaded" range on the dipstick, but still below the higher of the two little holes. That's after running the engine briefly and letting the oil drain back.
Ditto on adding some oil to the filter before installing it. But you will most likely spill some before you get the filter screwed on if you put too much in it. Not enough to worry about, just so you know it'll happen.
One other little note - if you punch a couple of holes in the old filter and let that thing drain before you remove it, you won't have nearly as much oil get splashed onto the hose and undercarriage.
Norm
Old Dec 30, 2008 | 01:15 PM
thuxel's Avatar
thuxel
Dude chill, I was just joking.
I'm not the one who had to post how much oil does my car need.
You have already proved how ignorant you are with the post.
So there!
I win.
