S197 Rear Seat Weight - FINAL DISCUSSION (actual lbs)
I keep getting several different weights for the rear seats (upper and lower) on any 05-09 S197. One says 15lbs, while another says 40lbs- what the heck?! I decided that this should be decided once and for all-
(stock, fold-down, cloth) How much do a set of rear seats weigh?
Sounds good, so you took them out, put them on a scale, and the offical weight is?
I've had that thing in and out many times and usually pull it out with one hand not even having to bend the wrist lol. It's not even worth removing IMO! I'd have to say closer to 10 lbs...for I guess what would be called the "lower-part". can't imagine the top being any heavier...
There are two parts to your seat. The seat bottom (you sit on this part) that comes out really easy. Then the seat back (the part you lean on), that has a couple bolts to remove it
