Problem with hood on Highway
RE: Problem with hood on Highway
I haven't had problems with my hood until I got my intake a tune. I took her over 110MPH and noticed my hood was shaking up and down. Scared me, somewhat, but there's no way I'm going to stick pins in my hood. Maybe if I had stripes, maybe if I had a scoop, but my hood is as plain as can be and I like it that way.
The hood popped open at 30 mph on my '85 GT when it was only a couple of years old. Almost $2k worth of damage at that time (1987-ish).
Of course it was operator error; I didn't close it right [:@]
ORIGINAL: Gloves
When i watch racing on TV, it seems that they usually have 4 hood pins!
is that becaues they don't have a center latch?
Redfire you are correct; There are 4 rubber adjusters stops along the front support area under the leading edge of the hood. I used chalk on them to see if they were touching the hood when closed (2 weren't at all). Back them out some if this is the case. The way I close my hood is to drop it from about 18"up. From much less than that it won't shut because of the compression on these stops. I don't see any movement at 100+.
